I'm blowing fuse #8 on a Late - 72. Turn key and POP. Remove relay (914rubber new relays) and all is good until I put the relay in then POP.
Checked Wiper wiring and is correct. Disconnected the blower, cigar lighter, and horn still get the same. Which means if I'm reading the diagram correctly it should be in the wiper circuit? Could it be the motor itself? Last thing I want to do is remove everything to get the wiper out.
