QUOTE(GregAmy @ Apr 19 2020, 01:05 PM)
I believe that's normal? I had some on mine. Those are wear points where the tank can rub on the frame and rust through (mine rusted through on the right lower area in your photo. Leaked every tiem I filled the car all the way up until I figured it out).
The carpet under the fuel tank isn't a wear point. The carpet retains water, causing the tank to rust until there are little tiny pinholes in it. Then you end up chasing your tail trying to find where the fuel smell is coming from.
Been there, done that. Still have the tank with the rusty spot. I would suggest replacing the carpet with some neoprene wet suit material or similar that won't retain water.
