QUOTE(76-914 @ Apr 20 2020, 10:22 AM)
QUOTE(sjhenry1075 @ Apr 20 2020, 06:18 AM)
I actually tried a Pertronix, but was never able to get it to work correctly. With the points, the car fired right up. I'd like to keep it as close to original as possible, but finding a dwell meter is turning out to be quite a task.
That's odd. I've never heard that one. Usually it's the guy that didn't read the instructions and fried the Pertronix. They stand behind their products. If you feel you received a defective unit, call them. Great product support. Place a WTB: ad for a Dwell Meter in our Classified Ads section. Should be lots out there from the guys that have already switched over to Pertronix.
I understand and thought maybe I had fried it. I pulled it from the box, and using the supplied directions I put it into the distributor. I was very careful not to leave the key "on", as I read that it would fry the unit. I went to start and got nothing. I checked for a spark and there was nothing. I checked the wires since I know solid core wires are not compatible but I did not have solid core wires. I double checked to see if I had assembled it correctly and everything looked correct. I removed the Pertronix and put in a brand new set of points/condenser and got a spark.
Maybe I did fry the Pertronix, and I plan on contacting customer support. At this time I just want a dwell meter. Thank you for the advice to post something on the classifieds (WTB).
