QUOTE(Cairo94507 @ Apr 20 2020, 07:18 PM)
I would listen to Superhawk996 - but that's just me.
Thanks for the vote of confidence. But no one should listen blindly without questioning.
Heres a good example for doubters w.r.t. loading.
If you had the trunk loaded with gold bars, you would have more grip at the rear and the rear brakes could exert more force without locking up. However, if you had the gold bars in the frunk, there would be very little grip at the rear and the rears will lock up sooner.
Modern ABS and stability control systems use electronics to vary the quantity of rear brake line pressures in response to loading. We now try to maximize the amount of work the rear brakes do early in the stop before weight transfer to the front occurs. By doing this stopping distance can be shortend significantly. However, it also has the effect of tending to wear the rear brake pads much faster than what people were historically used to.
It used to be very common to go though multiple sets of front pads to a single set of rear pads. New cars, often go though two sets of rears to each set of fronts. Go figure. No free lunch!
