Teeners
I have finally gotten around to hooking up the anti-sway bar using 914Rubber plastic inserts (bushings?).
When we drive the car there is thumping noise within the rear that started once we had the anti-sway bar connected.
I made sure all of the connections are tight and not stripped. Might the rubber mounting brackets need grease? I am thinking that this might be a binding a then release event that is creating the noise?
Any thoughts or direction?
