Hey guys,
Continuing to hunt down issues when first starting the car, I decided to crack open the AAR Valve and cleaned and lubed per other threads on here and Pelican.
My question is where to set the heater element to spec.
I set it to where it was when taken apart and heated the element with a heat gun (to simulate the voltage from the electrical connection) to check for movement and while it did move...it didn't move much and air wasn't flowing.
So my question is a follows....(assume 68 degrees ambient temp)
-----How do I set the element and valve rotation to achieve this? Should I try and heat water to 122 degrees (full closed spec) and set the valve to that??
Thanks in advance!Click to view attachment
