QUOTE(Literati914 @ Apr 22 2020, 08:41 PM)
Look at the same area (well, feel rather than look) on the Left hand side of the engine bay..if it hasn't been replaced (that side usually doesn't need to be), then you'll notice a finger sized hole in the area you'd imagine it would drain from. Same hole should exist on the driver's side. IF someone hand formed and repaired the hell-hole area for a repair in the past, they may have mistakenly not included it. You need one tho, and could add it.
OK, I can't find it in my shop books, and the heater fan's in the way. Thank you I'll keep on. I need it as the "hole" is fine. Add it for sure.
