The job is done and only lost about 1 tbs of fluid since the @$$ end was not high enough on ramps sitting on 2x6s. So wheeled out the jack and boosted it a bit more and stuffed a paper towel in the hole to prevent more.
Mine took a 13mm wrench to remove the retaining bolt and a big A$$ wrench (bigger than my largest numbered wrench) to remove the nut holding the L assembly to the bushing. Channel locks used to remove the assembly.
Needed a punch to get the gear assembly out of bushing.
If I had to do it over again, instead of pushing the bushing in first and then connecting the speedo drive to it, I should have connected the speedo drive to the L first and then oriented in the tranny. Also a mark on the side of the bushing would have helped orient it with the retaining bolt.
Not a tough job just getting things aligned was the only challenge Thanks for all the help.
