Highland
Apr 24 2020, 03:01 PM
The markings on my windshield side moldings were polished off. Is there any way to tell which side is which? The only thing I can tell by test fitting is that the molding may be a tad long along the A-pillar if installed on the incorrect side.
Help
Mikey914
Apr 24 2020, 06:19 PM
They really only fit correctly one way. But they are also stamped L and R in the side if you look closely.
iankarr
Apr 24 2020, 09:19 PM
but I also seem to recall that the L and R stamp don't follow the standard where R is passenger side. I think they're stamped as if you're facing the car. Can someone verify?
Mikey914
Apr 24 2020, 09:35 PM
I thought they were fro the sides of the car, but now you mention it I'm not sure. Maybe they should have used 1 and 2 like aircraft.
Highland
Apr 24 2020, 10:07 PM
According to the thread I read L is the passenger side, so they are L and R facing the car.
But as I mentioned my markings have been polished off. Is there any other way to identify? The fit is not obvious to me.
Mikey914
Apr 24 2020, 10:16 PM
They are not the same leg length. If you lay them in place, and look for correct center clip spacing it should be right. There is more of a bend in the vertical too.
