I have the engine bay down to the metal and getting ready to paint. I'm wondering if I should use epoxy primer for this area, or an engine paint such as the Rust-Oleum engine primer/enamel that is made for high temperatures?
bbrock
Apr 25 2020, 10:22 AM
I'd treat with Ospho or similar if you haven't already, and then hit it with 2K epoxy.
Literati914
Apr 25 2020, 10:28 AM
You can get phosphoric acid products at a home store, which will convert micro rust to a paintable surface and promote adhesion. Be sure to rinse and dry, clean with a wax and grease remover before the 2K Epoxy Primer. I highly doubt the factory used a special primer in the engine bay, so epoxy would be a good choice.
roblav1
Apr 25 2020, 02:53 PM
Concur with Brent. Ospho and 2 part epoxy.
BeemerSteve
Apr 25 2020, 03:17 PM
Would RustMort do the same as Ospho?
