Porschef
Apr 25 2020, 12:08 PM
L-Jet
Driving home the other day, the car started to lose power after going over some very rough road and went another couple hundred yards before dying out. So I thought I may have had a bad injector but I was incorrect; although the pump was running it wouldn’t hold pressure. I could hear hissing from somewhere... Turned out to be filling #2 cyl with fuel
Long story short, a Noid light showed all 4 injectors open simultaneously. Pulling the harnesses off the injectors allowed for fuel pressure holding. It would appear that the ECU has crapped out.
I’ve read that they rarely fail, but maybe this one did.
Has anyone had a similar experience?
Thanks
dr914@autoatlanta.com
Apr 25 2020, 02:46 PM
maybe a bad head temp sensor?
QUOTE(Porschef @ Apr 25 2020, 11:08 AM)
L-Jet
Thanks
Porschef
Apr 25 2020, 02:51 PM
Wouldn’t think so George, signal is open on all four, causing a fuel dump...
Spoke
Apr 25 2020, 06:08 PM
Could you have lost the ground on the top of the engine? I think that's where the injectors get grounded. The bumpy road means something came loose.
Porschef
Apr 25 2020, 07:55 PM
Hmmmm...
I’ll have a look Jerry, thanks.
cary
Apr 25 2020, 08:38 PM
Im with Jerry, D jet grounds ...... or that little braided ground
strap in the dizzy. All are instant stops. Go, No Go.
porschetub
Apr 25 2020, 10:22 PM
Or water in the plug or the ecu…sounds like all your injectors have gone to ground water will do that,had this issue with my 944 hydro-looked the engine,just saying ok.
pt_700
Apr 27 2020, 11:54 AM
several years ago, my '71 d-jet wasn't getting fuel. after trying all the usual stuff, i had it towed to a local well respected shop who also tried all the usual stuff before swapping in another customer's ecu...
they fail almost never...
