QUOTE(stownsen914 @ May 2 2020, 05:33 AM)
You probably thought of this already, but if a piston contacted a valve, you might want to replace rods bearings to be safe.
Good advice, but fortunately not the case. Pulled all pistons, cyls to inspect and re-ring. Heads all the way apart, 5 angle grind - all straight and fine.
Not really sure exactly why the p rod bent, but there was no other damage.
Mysteries abound..
