2 pair of 911 front struts.
The first pair is from a ‘69-911T. These would be the same struts that came on a 914-6. Early pinch bolt style would use the same ball joints as an early 914-4 or 6. Some very light rust on the barrel along with old undercoating. Bearing surfaces are in very good condition. No hardware is included. $350 + ship.
The second pair are from a later 911T with a wedge bolt style ball joint. These would fit on any 914-4 or 6 with the correct ball joints (used ones included). Includes a used insert in unknown condition. I can remove prior to ship to lighten the box a bit. Very good bearing surfaces. No hardware is included. 495 + ship.
Both these struts will fit stock 914-4 or 6 strut inserts. I can also supply 911 hubs to fit. Email - Mark@MarkEpstein.net to purchase.
