I've just done the steering column bush - with a great result. I put everything back together.
I didn't record which washer fluid pipe went on which steering column tube. There are two. Top and bottom.
I guessed which one went where. Now the washer doesn't work. Trouble is, as I only just bought the car, I don't know if it worked before.
I've connected the spare wheel to the washer - and I know I have compressed air in the washer tank. But when I go to operate the washer on the stalk - no water.
Any suggestions? Do I need to completely dismantle the steering wheel job again? Hope not....
