I'm having issue with headlight synchronization and hoping your diagram and perhaps a reply could help me sort out the details...
- Both headlights Hi/Lo work, however it's a 1 Up and 1 Down situation
- Left headlight operates perfectly in relation to the switch.....when switch is pulled out the headlight turns on and flips UP just fine.
- Right headlight operates in the 'opposite' manner - meaning it is UP with the switch OFF and turns on and flips DOWN when the switch is pulled.......leading to a head scratcher.
I've pulled the relay on the RIGHT light and tried to cycle thru manually with no result......wondering if the wires to the RT motor are somehow not lining up with the proper pins ???
Any help from the group would be great !
