wbgoggans
May 1 2020, 10:22 PM
tips for e21 brake upgrade? what all do i need for upgrade on 72 914? Is it worth it? any other brake upgrades?
Mikey914
May 2 2020, 12:40 AM
If you are running a 6 or something with more than stock maybe. The stock brakes with good pads are pretty good. Eric @ PMB performance has some options. We even stock his "re manufactured" units. His turn around isn't usually too bad also.
wbgoggans
May 2 2020, 12:52 AM
QUOTE(Mikey914 @ May 2 2020, 02:40 AM)
I plan on buying new rear calipers, however I've heard e21 front calipers are a huge upgrade and seem to be cheaper than buying rebuilt front calipers. I have already installed a new 19mm brake master and braided brake lines but have yet to drive the car since purchase.
914Sixer
May 2 2020, 06:12 AM
PLEASE go to the Classic section and read up on everything you need to know about brake systems. LOTS of urban legend stuff discussed.
JFJ914
May 2 2020, 08:33 AM
Waste of time and money. All you'll be doing is putting more heat into the non vented discs. Good for bragging rights though.
Gatornapper
May 2 2020, 08:56 AM
My car came to me with e21's in front, and I got my rear rebuild's from Eric at PMB Performance, and a new 1/2 caliper for the right e21 that was cracked.......Eric told me the e21's were a step backwards and put original 914 front calipers on for more balanced braking.....
Haven't done it yet.
But on 914 brakes, I think no one is better than Eric.
GN
QUOTE(wbgoggans @ May 1 2020, 10:22 PM)
Jett
May 2 2020, 09:14 AM
I had e21’s on our 75 2.0, but replaced them for a stock set from PMB.
Porsche brakes are great when properly serviced.
BENBRO02
May 2 2020, 09:36 AM
If you want better braking your money is better
spent on performance rubber.
914e
May 2 2020, 02:08 PM
Cooling ducts might be a greater improvement.
Chris914n6
May 2 2020, 02:18 PM
Can't "upgrade" the fronts to larger pistons without doing the same for the rear, which would be -6 rear calipers, but if you can find them they cost more than a full set of rebuilt stockers.
So the correct answer is get the stock brakes working 100%, use modern FF or better rated pads, and modern sticky tires.
