Well for first post was going to be the big red flashy light which ohhh so many threads but I accidently found the cure after going through it over and over with no success the big flashy red went out with the cars RPMs brought up
History of the car is questionable but was brought to me for a body restoration which ended up with a front left clip replacement and some minor rust repairs aside from the hell hole. once I was finished with body and paint it was sent back to the owner who did a bunch of assembly and swapped all the bulbs to LED now this car was not running when purchased and also had previous electrical love, it went to the mechanic to have the motor installed and to get running (18 months later we pulled the car not running or barley worked on.
Don adopts a headache , got the car igniton wiring all straightend out installed Pertronix! got car running nicely too! Did the brakes all around and it runs and shifts and stops and did the joy lighting gremlins from hell! after hours and hours and swapping bulbs and bases and swtiches...... perhaps a puff o smoke once too lol
went into the shop at 3 am this morning and retraced all wires for signals front and rear cleaned all the terminals up.
1) car running headligths off left and right front turn signals work as they should but the opposing bulb has a very dimm flash
2) car running headlights on front signals work perfect no opposing flash
3) 4-way flashers work as they should have tried 3 flashers attempting to fix other issues
4) the problem is that the rear turn signals both flash when trying to turn right or left?? any help or thoughts would be appreciated
