Saw this on Dennis Deeds IO group, know nothing about them, just passing along..
EBS Racing/Parts Heaven 50% Off
Pallet #4
914 Parts
$50 Minimium Order
Call or Email to Place Orders
Updated April 26 2020
EBS Racing Qty
Item Code Description 1 Description 2 Brand Retail Price 50% Off Avail
ENGINE
0 280 130 006 air temp sensor 914, 1970-76 Bosch $165.20 $82.60 3
0 280 160 102 vacuum limiter 914 73 Bosch $56.60 $28.30 1
021 101 481 SIL valve cover gasket Sil 912E /914/4 2 pack Real Gasket $69.64 $34.82 4
021 105 101 crankshaft 914 1.7/1.8 Porsche $585.25 $292.63 1
021 105 247 AV crankshaft seal front 912E/914/4 WW Racing $12.98 $6.49 1
021 105 275 lock plate 912E/914/4 OEM $1.50 $0.75 6
021 105 279 O-ring crank to flywheel 912E/914/4 OEM $1.50 $0.75 2
021 109 601 intake valve 39mm 914 1.7 OEM $9.50 $4.75 3
021 109 611 D exh valve 33mm sodium 914 OEM $74.00 $37.00 8
021 115 421 A oil pressure spring 914 Porsche $3.09 $1.55 4
021 115 487 breather cover gasket 914 OEM $1.50 $0.75 2
021 119 125 A o ring 914 Porsche $5.75 $2.88 1
021 119 751 thermostat cable 914 Porsche $48.50 $24.25 1
021 198 031 b oil sump gasket set 912E/914 2.0 OEM $2.50 $1.25 10
021 198 175 x1 piston ring set single per cylinder 914 OEM $32.00 $16.00 3
022 105 273 A flywheel 912E/914/4 OEM $360.00 $180.00 1
022 115 331 oil cap o-ring 914 1.8/912E OEM $0.75 $0.38 5
022 129 637 eng breather hose conn 914 OEM $5.78 $2.89 13
022 129 707 F intake gasket 914 1.7/1.8 OEM $7.00 $3.50 3
022 133 083 elbow 914 OEM $7.16 $3.58 1
039 101 275 oil temp sender plate 914 Porsche $46.45 $23.23 2
039 129 620 A air filter LX234 912E/914 1.8/2.0 OEM $14.75 $7.38 1
039 129 707 intake manifold gasket 914/912E OEM $10.25 $5.13 2
039 133 075 B paper gasket 914 Porsche $9.50 $4.75 1
039 133 241 connecting hose 912E/914 1.8/2.0 OEM $5.00 $2.50 4
039 198 075 BB single piston 96mm 914 2.0 AA Products $65.00 $32.50 1
039 199 231 engine mount front 914/912E OEM $17.25 $8.63 2
039 199 231 APA engine mount front 914/912E APA Industries $17.25 $8.63 4
039 256 297 nut M8 914 Porsche $15.00 $7.50 6
043 133 241 intake boots 914 1.7 OEM $4.00 $2.00 4
113 311 113 B main shaft seal 22x40x1 911 -71/914 OEM $2.25 $1.13 5
914 375 049 00 motor mount 914-6 APA Inc $150.75 $75.38 2
cam 00-682U
billet cam, 914 USED .465"/.465", 108 l/c 914 $100.00 $50.00 1
FUEL & EXHAUST
0 280 160 001 fuel pressure regulator 914-4 Bosch $148.00 $74.00 3
0 332 514 120 dual relay FI 912E, 914 1.8 Bosch $190.37 $95.19 2
0 580 463 016 fuel pump 914/4 75-76 Bosch $335.35 $167.68 1
000 071 347 914 2.0 tail pipe 914 OEM $39.50 $19.75 3
021 256 321 D exhaust clamp 914-4 Porsche $28.50 $14.25 1
021 256 322 B exhaust clamp 914-4 Porsche $24.00 $12.00 1
021 298 001 A muffler gasket set 914-4 1.7/1.8 OEM $50.75 $25.38 4
133 133 511 fuel filter 914 75- OEM $17.00 $8.50 1
311 133 261 fuel injector valve seal 912E/914 72- OEM $0.50 $0.25 9
311 133 261 A fuel injector valve seal 912E/914 72- OEM $0.50 $0.25 5
914 201 227 10 gas cap seal ring 914 Porsche $5.10 $2.55 1
914 201 893 10 fuel filler gasket 914 Porsche $8.56 $4.28 1
914 301 307 00 G support rod for throttle 356/911/914 Porsche $19.00 $9.50 2
914-6 HDR 1 3/4 racing header w/exh 914/6 MSD $865.00 $432.50 1
TRANSMISSION
901 423 253 00 bell crank bushing brz 911/964/930/914 OEM $2.00 $1.00 4
901 423 343 00 clutch clevis bushing 911 -86/930 -88/914 OEM $4.00 $2.00 4
911 423 341 01 clutch pedal bush, bronze 911 -86/930 -88/914 OEM $2.50 $1.25 6
914 375 025 00 transmission mount rear 914/4 NLA OEM $34.00 $17.00 2
914 423 401 02 clutch cable Gemo 914/6 OEM $45.75 $22.88 2
914 423 401 05 clutch cable 914/4 OEM $59.50 $29.75 1
914 423 401 05 clutch cable, Terry Cable 914 2/3 Terry Cable $59.50 $29.75 1
914 424 131 00 thrust spring 911/914 Porsche $4.50 $2.25 1
914 424 512 00 shift rod bushing 911/914 OEM $6.75 $3.38 3
999 110 014 00 ss 999 110 008 00 VP 911 -71 911/914 OEM $184.50 $92.25 1
SB 914L side shift conv bush 914 Perf Products $24.00 $12.00 1
SB 914S rod end bushing, side shift 914 $1.75 $0.88 1
FRONT AXLE & STEERING
901 341 049 04 ball joint APA 911/912 69-71/914 OEM $42.00 $21.00 1
901 347 191 02 steering rack boot 911 -89/912E/914 OEM $15.75 $7.88 2
901 347 223 03 rubber steering mount 914/911 Porsche $10.95 $5.48 1
911 347 322 04 tie rod ball joint 911/912/914 OEM $30.25 $15.13 2
914 341 422 00 control arm bushing 914 Porsche $14.25 $7.13 2
EBSR PB 3001 S A-Arm Bush, Front 911,930,914 69- OEM $35.00 $25.00 2
REAR AXLE
113 501 229 D CV joint bolt rear, hex 914/4, 8x45mm OEM $1.75 $0.88 50
WHEELS & BRAKES
211 611 775 B front brake hose 914 '72- OEM $22.00 $11.00 4
281 611 775 B rear brake hose 914 '72- OEM $14.00 $7.00 3
411 698 471 brake caliper kit front 914/4 -72 OEM $17.25 $8.63 2
411 698 471 A brake caliper kit front 914/4 72- OEM $17.25 $8.63 2
901 355 929 00 brake resv seals 911 65-76/914/912 OEM $5.25 $2.63 1
914 352 401 10 brake disc rear 914 OEM $46.75 $23.38 3
914 352 401 10 Z brake disc rear 914 ZIM $46.75 $23.38 1
914 355 603 00 brake line 911/912/914 Porsche $30.67 $15.34 2
914 356 201 00 grommet 356/911/914 Porsche $8.50 $4.25 1
914 424 551 01 parking brake cable, lft 914 OEM $46.00 $23.00 2
914 424 552 01 parking brake cable, rt 914 OEM $32.25 $16.13 1
914 424 591 00 parking brake boot 914 OEM $4.00 $2.00 1
BODY
022 256 206 B heater control flap rt 914 OEM $115.75 $57.88 2
111 837 581 J window crank VW/914 OEM $5.50 $2.75 6
321 837 581 01C Window crank handle 914 OEM $4.75 $2.38 3
901 559 210 27 front hood emblm, vintage 912E/914/924/T/928 Porsche $193.50 $96.75 1
901 628 341 00 wiper arm cap nut 911 -75/914 OEM $20.50 $10.25 4
901 731 133 20 mirror adhesive pad 911/930 -77/912E/914 OEM $3.75 $1.88 1
914 501 259 11 sway bar bracket 914 Porsche $45.11 $22.56 2
914 504 111 10 rear hatch weatherstrip 914 OEM $13.25 $6.63 1
914 504 155 10 front eng comp seal 914 OEM $19.75 $9.88 3
914 507 042 10 corner piece right 914 Porsche $57.96 $28.98 1
914 511 901 10 front hood seal 914 AFTERMARKET Tasker Metal $65.75 $32.88 2
914 512 319 10 rear window to lid seal 914 Porsche $43.12 $21.56 1
914 521 029 11 seat adjuster handle 914 Sierra Madre $22.48 $11.24 3
914 521 283 10 bell crank spring 914 Porsche $2.31 $1.16 1
914 521 284 10 bell crank spring 914 Porsche $2.31 $1.16 1
914 531 143 10 roll bar seal, vertical 914 left side OEM $76.25 $38.13 1
914 531 144 10 roll bar seal, vertical 914 right side OEM $76.50 $38.25 1
914 531 813 10 door seal outer left 914 OEM $60.50 $30.25 1
914 531 814 10 door seal outer right 914 OEM $59.25 $29.63 1
914 531 873 10 window scraper seal 914 OEM $7.50 $3.75 1
914 531 939 10 window slot seal inner 914 OEM $11.25 $5.63 2
914 541 907 10 winshield glass spacer 914 Porsche $3.50 $1.75 2
914 542 161 12 window guide 914 OEM $18.75 $9.38 2
914 542 171 14 G window guide 914 Porsche $19.36 $9.68 1
914 552 086 10 glove box knob 914 Porsche $26.00 $13.00 2
914 552 263 10 windshield seal 914 Porsche $76.00 $38.00 2
914 559 016 10 targa top holder clip 914 Porsche $24.66 $12.33 1
914 559 120 11 2.0 emblem 914 Porsche $46.75 $23.38 1
914 559 219 10 clip, roof holder rear trunk 914 Porsche $7.75 $3.88 2
914 559 231 10 funnel 914 Porsche $15.00 $7.50 2
914 559 267 10 jack recepticale cover 914 OEM $8.75 $4.38 4
914 559 287 11 914 emblem 914 Porsche $52.75 $26.38 2
914 559 293 10 914 1.8 Decal 75 914 1.8 Porsche $28.00 $14.00 2
914 563 071 10 top latch, front NOS 914 Porsche NLA $98.00 2
914 563 082 11 roof latch, right NLA 914 Porsche NLA $85.00 2
914 563 317 10 rubber pad 914 Porsche $2.98 $1.49 2
914 613 491 00 rubber cap, OEM 356/911/914 OEM $9.75 $4.88 1
914 628 741 00 rubber plug 911/914/928 OEM $5.25 $2.63 3
914 731 014 12 rear view mirror 911 69-77/914 Porsche $257.01 $128.51 1
914 731 116 10 mirror base gasket 914 OEM $5.00 $2.50 2
914 750 189 10 plastic sleeve 914 Porsche $7.00 $3.50 4
999 591 447 02 panel clip 911/914 Porsche $3.25 $1.63 12
999 702 091 50 grommet, drain tube 914 Porsche $9.50 $4.75 1
ELECTRICAL
0 130 007 002 ac evap fan motor only 911/914/912 1965-89 Bosch $95.50 $47.75 1
111 905 449 A spark plug boot 911/930/912E/914-4 OEM $1.75 $0.88 11
111 953 513 F turn signal switch 924 '77-'80/914 OEM $34.00 $17.00 1
914 347 713 00 pressure spring 356/911/914 Porsche $3.50 $1.75 5
914 347 832 01 horn switch 914 Porsche $29.50 $14.75 1
914 531 903 10 key blank black 911/914 OEM $25.33 $12.67 2
914 631 913 11 fog light lens 914 70-74 Aftermarket $26.82 $13.41 2
914 631 934 11 turn signal lens front 914, USA version Aftermarket $42.50 $21.25 3
914 631 937 10 turn signal lens front 914, Euro version Dansk $34.75 $17.38 2
914 631 945 00 side marker lens, left 914 Aftermarket $39.00 $19.50 1
914 631 957 10 front signal lens seal 914 914Rubber.Com $16.95 $8.48 1
914 632 107 00 defrosterlight assembly 911/914 Porsche $48.75 $24.38 5
Bosch 01052 ignition points 914 OEM $13.75 $6.88 2
SR 17X Bosch rebuilt starter 911 65-71/914 OEM $185.25 $92.63 1
SR 17X CORE Bosch rebuilt starter, core 911 65-71/914 OEM $100.00 $50.00 1
TOOLS/ACCESSORIES
Lit 489 020 200 03-72 Porsche Vehicles Used for Sports Purposes 911S & 914/6 1970-72 $50.00 $25.00 13
P 1017 drain plug socket 17mm 911/914 Sir Tools $28.00 $14.00 1
P 240 dial guage holder 911/930/914/356 Sir Tools $28.00 $14.00 3
P 241 spring clip 911/930/914/356/912 Sir Tools $2.50 $1.25 6
P wheel hanger Porsche wheel hanger 14m 986/996/997/914/356B Ralf Boothe $30.00 $15.00 1
Quantites are limited. Sale prices on in stock items only. Call or email for pricing on items not listed.
Sign up to receive weekly updates on Parts Heaven inventory specials.
Call or email to place orders.
