Tdskip
May 3 2020, 05:54 PM
Believe so but would like to double check.
Thanks!
914werke
May 3 2020, 06:22 PM
Yes
Tdskip
May 3 2020, 08:07 PM
Thanks!
Mark Henry
May 4 2020, 08:14 AM
1.7 rockers with stock adjusters would also work.
Tdskip
May 4 2020, 08:17 AM
Thanks Mark.
Asking because I have a 2.0l engine with 1.8 heads that needs to come at least partially apart (severe oil blow by, older threads) and I happen to have a set of 2.0L heads that came with the race car buy. Just wondering if the existing 1.8 heads don't look good if I can harvest bits for the 2.0L heads once checked.
VaccaRabite
May 4 2020, 08:35 AM
You probably know this, but if the engine is running with 1.8 heads your induction is not 2.0 induction due to the 2.0 requiring 3 bolt heads not 4 bolt heads.
If you swap to the 2.0 heads you will need to find the 2.0 intake runners and plenum etc to go with it.
Zach
Tdskip
May 4 2020, 11:59 AM
Thank you for the reminder Zack, happily I do have a set of proper 2.0 L intake manifold’s on hand.
Hope you had a good weekend and thanks again for the attention to detail.
