I've been going through electrical on my73 resto and have one last gremlin to chase. All of my lights work as expected including e-brake indicator flasher and hazards. One last thing that isn't working are the turn signal indicators in the tach. I'm thinking the flasher (still the original Hella unit) may just be getting tired but thought I get expert opinions.
The left indicator sometimes works as expected but often flashes correctly for a minute or so and then starts flashing both sides. The right indicator almost always flashes both sides. Rarely it will flash correctly. Neither indicator flashes when the hazard switch is pulled. Can't remember if they are supposed to flash when hazards are on.
There are NO LEDs in the flasher system. I figured I'd take that out of the equation for troubleshooting. I should add that this is just running off the fully charged battery at 12v. No engine installed. This is a fully refurbished harness and I've triple checked all my switch and bulb connections. After scratching my head all day, I'm thinking the flasher may be just at it's limit of being able to respond to the load. I can't say I fully understand how this funky circuit operates though. I plan to switch to all LED signal and indicator bulbs and have read the thread by @Spoke on LED compatible flashers. I just thought I'd check if there is anything I've overlooked.
I did pop my flasher open and it is clean as a whistle inside. I wonder if replacing the two capacitors would rejuvenate it.
