Hey everyone - new member here both to forums and 914's (Have owned an 83 sc for a while though)
I purchased a 1974 2.0 locally in my area last fall and I am just now getting it out to start doing some work. The car is in awesome shape with no rust what-so-ever apart from a bit of surface rust here and there. The car runs great as well but for some reason suffers from a hesitation right at around 3500-4000 rpm in any gear. My plan is to go through the ignition system and replace anything that is worn while also adding a pertronix ignitor II. I have already ordered the ignitor after some discussion with a lady at Pelican Parts but I just want to make sure I ordered an appropriate system now that I actually have the car out and can see the distributor. I ordered the Ignitor II meant for cars with original vacuum advance which I assumed would be standard on the 2.0. After getting the car out I noticed that the distributor is only fed by one vacuum line (the retard I'm assuming?) Pertronix only has one part number on their catalogue while pelican and AA both have two however? I ordered the 91847V which is the correct one shown on the catalogue but this correlates to the part meant for cars with vacuum advance on both other sites. Can someone with some prior knowledge of this give me some clarification here? I'm just trying to make sure I have the right part and dizzy here before I go and start installing. (The car still has the D-jet if that's important)
Thanks.
