IMHO the idea that these cars can't tolerate water is absurd.
In the case of the suspension console ears, longitudinals etc., the issue isn't that the water gets in, its that the drain holes get plugged and the water can't get out.
The usual culprit is some DPO or dealer that applied undercoating over everthing on the underbody and blocked the drain holes.
The suspension console has a drain built into it as do the longitudinals. These need to be kept clean and clear. There are also drain slots in the Frunk below the gas tank that need to be kept clear.
@cuddy_K May be fodder for your awesome newbie video series?
This situation is not unique to 914's.
My Miata had various drains that had to be kept clear. If the convertible top drains got plugged, you get a wet carpet on the rear shelf and a humid interior and window fogging galore. The rockers (longitudinals) also had drains. When they would get plugged, you could hear the water slosh in them when accelerating and decelerating.
In these cases, it was typical road debris that would eventually build up, blocking the drain. Creative use of coat hangers, or pick tools would eventually clear the debris and a flood of water would pour out.
Just food for thought. It isn't like these cars weren't designed to be driven daily in any sort of weather.
