QUOTE(Al Meredith @ May 7 2020, 08:34 AM)
I'm in the process of rebuilding a couple of 914 transmission and found two with the early intermediate plate. One has the bolt hole tapped and the other has the hole with a plug in it. Anyone know what the going rate is for these parts for a 6 conversion ? Al
Well for comparison patrick gets about 150 for a cable that doesn't use a bell crank. The bell crank conversion kit from Rich Johnson is about 450 but half of that cost is the bell crank, linkages and cable so that would all be parts you would need for your plates.. So just thinking a $200 premium for the plate added to a trans??
