Took the car into the city yesterday to visit the Cemetery and place Mothers Day flowers. It has been running flawlessly, So no issues taking it anywhere. Stopped a couple places and it started right up, then it didn't....
Turn the key, hear the fuel pump buzz, turn key to start and nothing.. Did hear the pump buzz again. crawled under the car to check the solenoid wire and it was connected. couldn't get a good grip on it to pull it off.
I was on top of a hill and only had to push it a few feet to get it rolling and it caught right away. Made it home without issue. doing mental trouble shooting on the drive home, I figured either starter of ignition switch. It was charging fine on the drive home.
But pump did buzz when key was turned all the way. which would rule out the switch.
Anyways got it into the garage and up on the lift. and connected a pushbutton starter switch to the solenoid and the starter cranked. then plugged the yellow solenoid wire back on and it started. Whew...
Pulled the wire back off, cleaned the terminal and tightend up the wire end. plugged back on and everything is good now.
BUT, now you have that question in the back of your head. did I solve it or is it an intermittent problem that will rear is ugly head again in the future...
So lets play Devils Advocate here and guess what OTHER things I should check to rule out or eliminate the problem.
I have a wiring diagram here, but have not checked it yet.
