Ampex351
May 9 2020, 11:54 AM
I bought a new set of center caps and want to replace the old ones. What's the best way to go about it without tearing up the caps? They seem to be really stuck on there.
Thanks, Roger
jack20
May 9 2020, 12:32 PM
Here’s the way I did it. Remove the wheel. Use a drift or something similar. Tap the edge of the back of the cap where it meets the inner bore, going all the way around. It will come out with a little patience.
Jack
914_7T3
May 9 2020, 12:45 PM
You can make your own removal tool from PVC pipe, works great!
https://www.thesamba.com/vw/forum/viewtopic.php?p=7914550
May 9 2020, 01:30 PM
QUOTE(914_7T3 @ May 9 2020, 02:45 PM)
https://www.thesamba.com/vw/forum/viewtopic.php?p=7914550 I purchased some PVC couplers that fit the front OD and the back ID. All of 4-5$ and it works perfectly.
Ampex351
May 9 2020, 02:01 PM
QUOTE(mepstein @ May 9 2020, 02:30 PM)
All done!! They look great. I got the SS ones with the crest in the middle.
Appreciate your help guys!!
KELTY360
May 9 2020, 04:39 PM
QUOTE(mepstein @ May 9 2020, 11:30 AM)
If you wrap a little thin foam on the inside of the OD side it keeps from marring the center cap when you reinstall the caps.
Steve H
May 9 2020, 04:49 PM
QUOTE(914_7T3 @ May 9 2020, 11:45 AM)
https://www.thesamba.com/vw/forum/viewtopic.php?p=7914550This is the way. You also buy a small piece of pvc and use it to install your center caps without any damage.
