Tjmrfe
May 14 2020, 12:24 PM
Ok,
Thanks in advance,
Changed my oil seals on my push rod tubes, with help fro y’all. So, I go to put the rockers back on...and strip my studs trying to put18 ft lbs of torque on them! (As per my “ how to rebuild your type 4 “ book, by Tom Wilson. So far he hasn’t lied to me...so, this happens to 3! Damn, so I order them from AA. And, wouldn’t ya know it. Trying to tighten on the studs AGAIN! I strip em. So, now I’m pisssed....now...I found a blog in samba, saying that 18 is way too much, so....I ordered another set from AA and lo and behold they stripped again with only 11 ft lbs..... I’m not doing well here.
Ready to scream...louder....
Has any one else had this? What am I doing wrong? Thank you again....
BPic
May 14 2020, 12:33 PM
Damn! That sucks and I feel for ya. I can't help but will follow this to learn. Good luck.
bretth
May 14 2020, 12:42 PM
If you are talking about the rocker studs that mount to the head then you probably need to put in something like a thread cert. Once that aluminum head material is stripped with the steel stud threads they are no good any more. Will need to drill for thread cert or similar.
914werke
May 14 2020, 02:45 PM
& if you are going to this extent upgrade to 8mm step studs, no more wimpy 11mm fasteners.
porschetub
May 14 2020, 02:51 PM
Used 9ft/lbs on last build and that was using the heavy 8mm studs for alloy valve covers.
TBO even that felt pretty firm.
As mentioned you only fix is to fit thread inserts or helicoils,would pay to check the others,it gets messy when rocker gear comes loose
Nogoodwithusernames
May 14 2020, 02:58 PM
Are your aluminum heads stripped or are the studs themselves stripping where the little nut holds the rocker shaft?
If the stud itself is stripping bump up to the 8mm heavy duty studs from the T4 Store (LN engineering) vs the stock 7mm stud.
type2man
May 14 2020, 04:17 PM
18 lbs is a lot. Is that what the book says?
Tjmrfe
May 15 2020, 07:30 PM
QUOTE(Nogoodwithusernames @ May 14 2020, 12:58 PM)
Thanks, yes the studs themselves, not the threads in the head ( thank God) so, that’s who I’ll try for the next round...thank you.
Tjmrfe
May 15 2020, 07:31 PM
QUOTE(type2man @ May 14 2020, 02:17 PM)
Well the book I have, lol. I thought so too. Have since heard that’s for a type one...this book deals with all three types.
