Normal range of my Mallory distributor is 10° to 28°, ± 2 to 3 depending on how it's setup.
With my Link Fuel Injection and Ignition controller, I am supposed to "lock" the distributor so that it no longer has any advance since the ECU now controls it.
The distributor is "locked" at full advance.
The problem I seem to be having is that I believe I am getting some spark scatter at the lowest setting due to the rotor armature being too far from the HT lead in the cap, and only at the lowest degree setting of 10°, I can move the distirbutor up to about 13° and it runs better but that is getting too high for easy starting.
I've repositioned the LED inside the Mallory, but with no luck....
So, I started to think, why not just keep the mechanical advance working?? Sure it'll move back and forth but the ECU will be sending the signal of when to fire and it should be fine....
Hope that made some sense
