I'm happy with the results of the several year restoration on my '71 with 2 ltr implant.
Although I kept the Tail Shift tranny, I did install all new bushings and rebuilt the shift rod cage at the very end of the linkage, welding and filling the worn slot between the shift rod pinion and shift rod cage. All in all, I think the linkage transfer is as good as it can get. Nevertheless, the shifting is vague (I know, right?) with the weakest link when upshifting to 2nd or downshifting to 2nd.
Examination of the in cabin shifter, doesn't reveal any warn components or weak springs but it has an excessive amount of "slop" which (I presume) is mostly a function of its design from the factory...
You guys in this forum are so good at providing insight and knowledge that I look to you'all for direction.
I'm thinking that the Rennshift shifter upgrade will provide a tighter transfer of movement to the shifter linkage and ultimately to the transmission.
If not Rennshift, then what?
thanks guys
Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment
