Brian Mifsud
Jul 8 2005, 05:58 PM
I have an opportunity to trade with a Bug/Ghia guy who wants my 4 x 130mm 15x5.5J Enkei wheels + tires for a set of 15 x6 and 15x7 Cookie Cutters.
Anyone running these under stock fenders?
Will be using the proper hubs, not wheel adapters.
Thanks
Brian
Aaron Cox
Jul 8 2005, 06:00 PM
they are same offset as fuchs...
205 tire is all that matters.
ill be running 7" cookies with 225's under "Massaged" fenders
Mueller
Jul 8 2005, 06:03 PM
Brian,
Some people claim it'll fit on the rear with no pulling of the fenders, on my old 914 I had 16x7 Phonedials with the same 23mm offset (those Cookies should have that offset) and 205/50 tires...I had to pull out the fenders just a tad bit near the trailing edge of the fender openings.
Brian Mifsud
Jul 8 2005, 06:06 PM
Very Cool.. I am aware of the typical assymetry car to car.
So I'll be cautious with my baseball bat.
Thanks
Brian
Bleyseng
Jul 8 2005, 07:38 PM
I run 15x7's cookies with Kumho's for my AX/track tires. It took alot to fit the back finally stretching the back out with a old Boge shock insert. Many passes and lots of cracked paint and they work gud.
I had to due the fronts too. now I need to repaint the effin car besides all the other crap to be done.
Joe Bob
Jul 8 2005, 09:24 PM
I have 15x7s on Manfred with 205/50s...the rears are poofed out a bit, but look like they can handle 225s.
campbellcj
Jul 8 2005, 10:35 PM
Same here...stock fenders but pulled & rolled a bit in the rears, and I run 15x7's (Cookies) and 16x7's (Fuchs) with Kumhos and Hoosiers.
Keep in mind the tire choice does make a difference. Tire makes and models can vary in section width and tread width, within the same nominal size. Hoosiers run wide.
