QUOTE(hndyhrr @ Jun 7 2020, 06:52 PM)
QUOTE(rgalla9146 @ Jun 7 2020, 06:20 PM)
Not there.
The air hose for 4cyl wipers is on the vertical wall in front of the gas tank.
Low on the passenger side.
I know it comes out there but how does it get there? What am I missing?
It looks like you missed a step. It there is a hose that goes from the spare tire to the reservoir for the wiper fluid. Then a hose that goes on the the turn stock and the wipers.
The hole you war looking at is on the reservoir side of the bulkhead. There is another hole on the spare tire side in the lower left corner (if your looking from the front of the car into the fronk. There is a grommet on that side that the hose goes through (also used on a hole on the other side under the gas tank for the wire that goes down to the master cylinder) You can see an illustration (and tge grommet) here
https://900designs-container.zoeysite.com/hose-grommetHope that helps
