Tdskip
Jun 8 2020, 09:24 AM
Hi guys - happy Monday.
Could someone check me on this please: if I use a 911 front strut and 911 a-arms do I need anything else to run a 911 under the body sway bar?
Thanks!
colingreene
Jun 8 2020, 10:04 AM
the struts are not important to the under body sway bar.
Only the a arms and the mounts for the sway bar that go from the body to the cross member are needed.
that is how my car is set up
Tdskip
Jun 8 2020, 10:06 AM
QUOTE(colingreene @ Jun 8 2020, 11:04 AM)
Good morning - thanks for the response.
So sounds like I need to source a 911 crossmember then.
Jun 8 2020, 10:14 AM
QUOTE(Tdskip @ Jun 8 2020, 12:06 PM)
No. The 911 crossmember is almost identical to a 914 one. There aren't any different mounting points.
A arms are also similar but have different number of splines for the torsion bar but if you use an underbody swaybar, it will use different mounting points (on the a arms) than the through the body bar.
914Sixer
Jun 8 2020, 10:51 AM
Under body 911 bars ONLY work with the aluminum crossbar and the metal tab bars holding the bar
Tdskip
Jun 8 2020, 10:53 AM
Thanks gentlemen, got it now.
Thanks!
Chris914n6
Jun 8 2020, 12:27 PM
It will work with the stock round steel tube crossbar. Just need to drill & tap for one of the bracket bolts.
Tdskip
Jun 8 2020, 02:19 PM
Thanks Chris
Tdskip
Jun 11 2020, 08:00 AM
Just following up here to make sure I understand and this thread is clear for future use.
The 911 aluminum crossmember started with 1974+ cars or started with SC? I think '74+ but would be good to know.
The reason you want the aluminum one, other than weight, is that it has premade mounting points for the swaybar mounting points, correct?
Thanks!
brant
Jun 11 2020, 08:21 AM
QUOTE(Tdskip @ Jun 11 2020, 08:00 AM)
Thanks!
don't quote me on this
but I think later than 74
I want to say it started with the 930
maybe 76
the aluminum cross member is rumored to be less strong and have flex
that is debated though to some extent..
Its an expensive piece that saves a little weight
fell within my weight formula for building my race car
$50/lb
Tdskip
Jun 11 2020, 10:06 AM
Thanks
@brant .
So just to run this to ground (if we haven't already, sorry) are there any earlier / non-aluminum crossmembers that have the correct under the body sway bar mount provisions?
burton73
Jun 11 2020, 03:07 PM
Tom,
I sent you a PM. I think I can help you on this.
Bob B
Tdskip
Jun 11 2020, 04:14 PM
Thanks Bob, helpful as always!
It would still be good to know if any of the earlier cross members support the under the body set up. Don’t think so but want to be explicit.
burton73
Jun 11 2020, 04:26 PM
Tom,
The arrow shows the rubber holder for the ends of the sway bar. Some one sells these parts to weld on. Tarret may be the people
Best Bob
burton73
Jun 11 2020, 04:33 PM
Front Sway Bar Bushings;
Click to view attachment Kind of looks like this but this is not it.
Bob B
burton73
Jun 11 2020, 04:43 PM
Porsche 911/930 FRONT Sway Bar Bushing for 20 mm Bar Set of 4 O.E.M.
$42.75
Free Shipping
[attachmentid=748042
OK this is what you want if you go with the under sway bar
Bob
burton73
Jun 12 2020, 11:18 AM
Tom has a 67 912-steel rack. Will 86 Carrera A arms and torsion bars fit right as far as the splines go?
In my build for my V8 car, steel would be better because of me having to move one body brace to fit my 3 master cylinders
Bob B
Chris914n6
Jun 12 2020, 12:41 PM
^^ Yes. Mine is Carrera susp on the stock 914 crossbrace as it fit better with the radiator hoses.
Had the Al crossbrace before I did the waterpumper swap.
burton73
Jun 12 2020, 01:33 PM
What do you use for the spline on the torsion rods? Are you using an A Arms that are Carrera and end adjusters are also Carrera? I am a little confused but at 68 years old that is happening more that I would like.
A steel unit would work better for me than my Aluminum cross bar because of how I had to mount the 3 master cylinders for clutch and brake.
Bob B
andys
Jun 12 2020, 01:54 PM
QUOTE(burton73 @ Jun 11 2020, 02:43 PM)
$42.75
Free Shipping
Bob
There are two sizes of sway bar, 20mm and 22mm (I think that's right??), so the sway bar bushings may be different; might want to check on that.
Andys
Chris914n6
Jun 12 2020, 04:20 PM
^^ the adjustment caps match the torsen bars which match the arms... so all 911. Just the crossbrace is 914.
SC is 20mm, and the Carrera is 22mm, I think. I know my Carrera is not the smaller 20mm.
Tdskip
Jun 12 2020, 05:20 PM
QUOTE(andys @ Jun 12 2020, 02:54 PM)
Andys
Thanks that is right.
