The 14 pin Male connector I used to mate to the 914 female is 911.612.113.05 I just moved the pins around to work correctly with the 911 harness. I bought my connector back in 2001 for $23.95 from Zimms Autotechnik
Apr 20 2021, 03:54 PM
You can still buy the connectors new which may be better than 50 year old plastic.
rgalla9146
Apr 20 2021, 04:33 PM
A bit faded and chipped on one end but certainly usable. PM your address Rory
Retroracer
Apr 20 2021, 05:02 PM
Think Pelican or AA sell them? The plastics go brittle with age, so would recommend new housings rather than reuse, FWIW
- Tony
bdstone914
Apr 20 2021, 07:17 PM
QUOTE(RiqueMar @ Jun 8 2020, 12:17 PM)
Hi All,
Looking for a 12-pin female connector housing (used on the relay board / steering column).
If not possible, not opposed to a 14 Male-female set.
I have a make and female 14 pin connector with leads.
IronHillRestorations
Apr 21 2021, 03:20 PM
@RiqueMar I have new male 14 pin connectors, and 12 pin female connectors. I'll get the part numbers for you. You can order them, or I'll sell you one of mine
