After a drive over the weekend I noticed the cloth braided rubber hose coming out of the top of my six is "sweating" oil. 4 or so inches of it, to be precise.
I know enough to drop my engine, adjust valves, rebuild carbs, but when it comes to flat sixes and what everything does I guess I'm not as clued up as I thought... because I figured given this goes from the top of the engine to the rear fender oil tank that it was either some kind of oil return line or an overflow line, but when I removed it the tank end is blocked off.
Hopefully someone smarter than me can tell me what it is. When I removed it I don't see any signs that the rubber has dried out or has cracks in it, but I guess I should replace it and the clamps because something's obviously going on that shouldn't be.
