I fitted the radio today but there does not seem to be any wiring in place to provide the live feed
I connected to the switched live (red wire) for the seat belt light and hooked up one of the speakers
everything worked OK until I started up the engine then I had a lot of interference.
Is there a better live to use, one that is supressed?
BPic
Jun 9 2020, 03:02 PM
You need to go directly to the fuse panel. I used number 9 I believe. It has 2 red and white wires. Red and white is switched on with key. Use a piggy back connector and you’re all set.
914Sixer
Jun 9 2020, 05:22 PM
Factory harness plugged in to back of lighter. Red is hot and brown is ground. Your alternator may missing RF block. Your plug wires should be shielded. Added Blaupunkt/Bosch information. Most cars never used the shielding kit.
dt4
Jun 10 2020, 01:35 AM
thank you
Ill check the plug leads and RF block and look at the wiring suggestions
dirk2056
Jul 30 2021, 10:42 AM
QUOTE(dt4 @ Jun 10 2020, 01:35 AM)
thank you
Does anyone know how to get good RF protection ?? Never had the radio in my car work properly??
914Sixer
Jul 30 2021, 11:08 AM
I may have a spare alternator filter. Have to look
windforfun
Jul 30 2021, 05:59 PM
I would put Pi filters in your + power supply lines as close as possible to your deck, crossover, amps, etc. A Pi filter is basically an in-line inductor with capacitors going to ground on either side. The schematic for it sort of looks like the math symbol for Pi or 3.14157...
