two weeks ago I drained oil, cleaned the strainer screen and taco plate cover, add new oil and filter and did the valve adjustments.
Before I did the valve adjustments, the compression rates (cold) was 150, 148, 165 and 175.
So after valve adjustments still cold engine, all are around 150. Is it a good compression as cold engine and what should I expect when the engine is warm?
thank you!
