So the 73 2.0 I bought has no AAR
I have got it running and it starts almost immediately and slowly builds idle speed to around 1500-1750.
I will have to pass an emissions test, and of course, this is likely too high to pass the first time. Rumor has it, the previous owner couldn't get it to pass either (before it sat for 13 years).
So... it obviously runs without it, lines have been capped. The cold start valve end is capped too.
I did the "spray starting fluid about and listen for differences" and think that I may also have a leak by the intake manifold (just at the plenum, below the throttle body) on the passenger (right/battery) side.
I discovered this missing component (no circuit to a decel valve either). I think I do have the MPS (only one hose)
Also, there is only a vacuum line at the back of the distributor... instead of both sides. The front is capped. The additional input into the plenum is capped.
Questions/Advice:
So is there a replacement part, or do I need used?
Is it really necessary, or just a nice thing to have (meaning can it idle properly without it?)?
I have read the decel valve is not needed.
