I just realized something Ian, isn't your muffler married to your heat exchangers?
Ian you need to take pics of the muffler flange to exchanger area.
I assume Ian (and I) didn't mention the make because we didn't want this to be become a pissing contest. His and my bad.
It's a Tangerine 2.0 -2 out. Personally I liked it, build quality and TIG welding is excellent and I liked the sound. Only bad was the issue with the O2 bung treads.
Ian and I dove 1-1/2 hours from the airport to my house, 70-80 mph, roof off, talked the whole way and we weren't shouting. I put a 1.8 Ljet in his 2.0, in sorting Ian's problems I daily drove his teen for nearly a month...loved it.
I can't remember but I've got a suspicion this one Chris modified/welded 1.7/1.8 SSI's to go on the muffler more like a 2.0. IIRC Chris used a non-stock flange arraignment. So Ian you might be looking at new heat exchangers as well, but you could get a fair buck for the Tangerine muffler and SSI's so that would offset some of the cost.
I don't know if this can be done with a Tangerine muffler but with other systems you could plug one of the tips to make it quieter. You would have to ask Chris.
Edit I'd also check the flanges and make sure they're tight and not leaking.
