check the white were plugged into the neg side of the coil, make sure that you read 50 degrees dwell on the points, make sure the ballast resister block is plugged in and that the ground leads at the back of the block are. tight then check the air flow meter to make sure that it is tightly connected to the intake boot and that the flap is flapping when turning over the engine
QUOTE(twin-grille-roadster @ Jun 11 2020, 01:56 PM)
Working on a friends '74 with the 1.8 engine.. We have no fuel from the injectors. it was running, shut down, then would not restart. I checked the ignition system and it is working properly. I have 38 pounds of fuel pressure. Found no fuel coming out of the injectors. I check the voltage at the injector and got 4 to 5 volts with the key in the run position but not cranking over.. The grounds seem to be tight and clean, and all of the injection components are plugged in properly. I assume the voltage should 12 volts but can find little in the way of specs. I did try another electronic control unit and it did not make any difference. Any thought or direction would be very much appreciated. By the way, it has four new injectors in it.
