Planning to replace rear bearings, I noticed that when I removed the rear axle nut (30mm), there was significant drag turning the nut on the driver's side all the way out, while the passenger nut turned freely after loosening. The driver side nut has resistance going back in after one turn then stops, while the passenger nut turns all the way in. Does this mean than the stub axle threads on the driver side is messed up? Can I chase this with a die or do I replace with another stub axle?
