QUOTE(RoadGlue @ Jun 12 2020, 08:44 PM)
Do you mean on the second fuel line? There's a lot going on in this photo, so it's hard to know what you're talking about.
The car has both a feed and return line for the fuel system, but if you car was swapped to carbs at some point, then the return line isn't used and may explain why it's disconnected.
The wire and connector hanging is the fuel level sender connection, which plugs in on the top of the tank.
sorry, I realise now that I wasnt very clear
you have answered all the questions between you
The car is on carbs which explains why there isnt a pipe on the return
