QUOTE(gereed75 @ Jun 14 2020, 09:01 AM)
There are several features on this box that indicate this is not a six box - the vent fitting on a six box is metal ( this one is plastic) and a box intended for Weber’s has holes between the inlet openings for the Weber vents.
The basic plastic boxes are all basically the same between sixes and various 911 iterations, it is some small details that vary. I believe that the vent fitting is equipped with a wire screen which is probably to baffle back flame events, I think?
The snorkel that points to the distributor side is unique to the six AFAIK.
Thanks Greg,that was a sample pic mine is standard plastic fare with metal vent,pulled it off yesterday and yes that part appears to be a flame arrestor,its a separate piece that press fits into the vent on the inlet end.
I will buy a piece of 1 inch hose and hook it up as I need to get rid of the K&N breather I have off the oil filler,its not really the most efficient system and I don't want to use a catch can.
