QUOTE(PanelBilly @ Jun 13 2020, 08:44 PM)
I want to go for a ride!
I see you are in the area. I commuted to Kent for 11 years, until recently.
Also, I was trying decide in what order to post pictures, but since I already got some questions, now I know.
I am cross-posting some pictures from some questions I got:
Question 1: Currently I have the Coldwater linkage setup and noticed you have the ZeroDecibel setup.....which I am thinking about buying if it will help the shifting. Have you any experience with the ZeroDecibel setup? BTW: This setup looks so clean and awesome.
A: I vaguely remember looking at the coldwater linkage. As far as the zero decibel part goes.. I like it.There are a few items, well more than a few, on the car that I just spent money instead of doing all the fab myself. It mostly happened when I ended up being blocked in several directions and I just needed parts in hand to make a decision to free some other stuff up. The shift linkage was one of those things. I am quite happy with it now. But it took me a long time to get to satisfactory shifting. Replacing all bushings from the MR2 shifter, making sure everything in the assemblies stay tight, torqued, threadlocker, etc., There is a lot of opportunities for play and flex in the MANY bolted joints if not properly torqued. Also I spent a bunch of time changing the shift lever length, welding new eyelets for cables on the MR2 shifter, etc. (I have had three different shift lever lengths in this car, all trying to get the ratios all lined up, hand position, and centering the shifter spring neutral position with the transmission is a pain. But i can say it shifts like a pretty good subaru now. Not like and S2000, but definitiely not like a 901. I built this car around me.
Just right (after new eyelets)
Click to view attachmentQuestion 2: It looks like you have installed an in-tank fuel pump. I did this on my brother-in-laws car but he does not have it running yet. I used an In Tanks and put it in the exact same place as you did, to take advantage of the fuel tank baffles. So, I don't know if it will be everything I hoped for. But, I am thinking about doing it on my car. What is the manufacturer of your fuel pump and have you had experience with this pump previously?
The fuel pump is an Hyperfuel n tank assembly. i am using the OEM level sender, but put the pump inside the OEM baffle. I had to fully refurbish the tank, and it required a bunch of weld repair, and I also welded up the outlet and return on the bottom of the tank. Remember to be careful welding tanks.
Click to view attachmentAfter all the care I took to make sure the vent/supply/return were routed properly, I still managed to get them messed up one time I took the tank out. This is not a good thing to do. The tank gets pressurized by the return, and you you force fuel out the vent.. There are others out there with better markings and different plumbing configs. but this one has worked great when properly installed..
On that note: when you relocate the pump to this location in the OEM baffle, you need to eliminate the expansion tank. Now you need a new vent solution that doesn't dump gas. I have iterated, and if you look close in the picture, you can see the vent line route from the pump assembly toward the driver side in front of the blower housing, as high as I can go underneath the cowl. This is routed against the liquid level during left hand lateral acceleration. This is then routed through a loop and then to a refillable charcoal canister. (Don't use ABS. I did) When I rebuild mine in new material, I will then be routing the fuel vent to the bottom of the car near the steering rack. I have zero gas smell in my closed garage (which is also my office these days).
Click to view attachmentI didn't retain the fuel pump controller from the donor car. I would have had I known what I was doing with this, it would have been much simpler than I thought at the time, considering I am running the both the WRX ECU and Chassis computer.
I do have an inertial switch for the fuel pump too. I often will disconnect this when I want to have the ignition on without the pump running.
I have about 5000 miles on this car in the last year, with zero issues with the pump or switch. And I haven't had any fuel fumes with the current vent configuration. I have also had it on the track and run it to <1/8th tank with no issues with the baffles. THe only think i plan to do is put and RC filter on the sender to slow it down a bit to the gauge during cornering...
