QUOTE(Mark Henry @ Jun 13 2020, 10:52 AM)
Type one push rod cut in half, tap for 1/4" threaded rod (IIRC), the rod, a couple of nuts...done.
You'll have to play with the length and remember you can't spin the engine the adjustable PR.
i pulled one of my old type 4 PR from storage. Had planned to give that a try today, but it is TIV.
On the length... I assume you cut the tube in 1/2, then maybe cut an 1" or so out of one end so I can "adjust" up and down plus the nuts.
Found this on TheSamba
https://www.thesamba.com/vw/forum/viewtopic.php?t=157398He is working on a type 1, so I assume he has a type 1 PR. He does not use the nuts. That seems to be critical IIRC. once you get everything aligned, if you don't use nuts the PR could "self adjust" as you remove it.
