914Sixer
Jun 13 2020, 09:02 AM
I cannot recommend this product as a replacement for the stock horn contact ring. 1st up the quality is not the same. Brass holder ring is only half the thickness of the original. The base where the wire comes through is thicker and slightly offset, making the 3 holes for the screws off center. If you file around the base as showing the the pictures you can make it work. Biggest problem is the wire length difference, it is only 13 cm long and the original one is 18.5 cm. When you put the wire through hole you are too short to reach horn pad spade.
Good news is I didn't over pay for this, so I thought I would pass information on.
dr914@autoatlanta.com
Jun 13 2020, 10:29 AM
you can use the factory 924 early 944 piece it works
Ansbacher
Jun 13 2020, 10:46 AM
Sounds like the same quality as their distributors- absolute junk. But they do have good mufflers.
Ansbacher
914e
Jun 13 2020, 11:07 AM
I have not found any reproduction horn contact ring for Porsche or VW that wasn't junk . Even on our bug I ended up buying one from a Porsche dealer.
What is wrong with your old one? The ring looks in good shape, every one of mine had worn through.
914Sixer
Jun 13 2020, 01:31 PM
Nothing wrong with the stock piece, only using it for reference.
