My horn was going on and off on its own, so I bought a blinker switch to fix the problem.
I bought a blinker switch from Sierra Madre and one from Jbuggs. Both came in the same white box. Both fixed the horn problem and everything else works, but when you turn a corner, the blinker does not cancel on its own. Same steering wheel and horn ring which worked fine on the previous switch.
I also noticed the cancel do hickey, does not stick out as far as the original one.
Any recommendations for one that does cancel on its own?
