@Spoke date='Jun 17 2020, 04:37 AM' post='2825828']
[quote name='mmichalik' post='2825641' date='Jun 16 2020, 03:36 PM']
@spoke - What would you need from me to do this. I believe you said in the past that I could send you the case / lens but, I do not have a set on hand.
The original bumper for the car didn't have the fog lights cut out like the replacement bumper does.
I would be happy to be a test case for you if I could.
[/quote]
@mmichalik Mike, could you take a couple of pictures of the foglight fixture? If it is similar or exactly like the 911 fog, we should be able to put LEDs into it. If if does look like the 911 foglight and will come apart, I'd like to get my hands on it to check fitment. If at that time you send one of the fixtures to me, I'll build a board and give you a set for your troubles.
[/quote]
The 911 fogs from 1974-1977 ? are the same housing as the 914 with the mounting bracket mounted in a different position.
The lens is used in other fogs that were used on Mercedes and BMW car of that era.
Your LED board should fit them too. Not many 75-76 cars were made with fog lights. Limited market on 914's.
