QUOTE(sharper @ Jun 18 2020, 10:54 PM)
Thanks everyone. I'm hoping to pull just the tranny out and not the engine. It's a converted 6 and don't want to deal with oil lines, fuel lines, wiring, etc. if I don't have to. Not to mention balancing the extra weight on a jack. Plus, I think the ramps will get me high enough for the trans but not the engine.
I think you've got the right idea here. Removing the tranny alone is a simple task and should not be a problem. As long as you can get the height, ramps will be fine. I see no problem using quality jack stands with a locking pin either.
As others have said, you do not need to remove the cv's, simply unbolt at the tranny and tie them out of the way. Having the ability to spin the wheels helps with this so jack stands would be my preferred option. Use whatever you have available to support the engine, wood works best for me. Goodluck
