Mikey914
Jun 19 2020, 02:19 PM
So as you know we make the easy install kit for these, this GB is not for that.
It is for the stock master cylinders we sell lots of the easy. These are the same high quality part just come with the difficulty of pushing the lines in like factory!
You can now save a chunk of change
76-914
Jun 19 2020, 04:36 PM
pm sent and no it's not a low ball offer.
rfinegan
Jun 19 2020, 06:14 PM
I am in for one...
Dusty’14
Jun 19 2020, 07:33 PM
Me too, I’m in for one.
Dobbsy
Jun 21 2020, 10:15 AM
Is this the correct diameter for a 914-6,
Mikey914
Jun 21 2020, 10:40 AM
Yes.
dlee6204
Jun 21 2020, 10:46 AM
In for one.
Dobbsy
Jun 21 2020, 11:10 AM
QUOTE(Mikey914 @ Jun 21 2020, 05:40 PM)
Yes.
One for me please
fiacra
Jun 21 2020, 11:23 AM
I'll take one.
PlaysWithCars
Jun 22 2020, 12:45 AM
Bummer. Missed out on the group buy a couple of weeks ago, but just installed it in the car today and it works great. Bump for a good member vendor and product. Take note: you must save the washers from under the supply line bushings on your old master cylinder to use when you install this one.
rudedude
Jun 22 2020, 08:59 AM
I'll take 2 at that price. Do you have turbo tie rod boots?
76-914
Jun 22 2020, 09:44 AM
per my pm, 1 please.
Jack Standz
Jun 22 2020, 10:15 AM
Please put me down for one.
Mikey914
Jun 22 2020, 05:31 PM
I will be throwing the washers OEM Porsche for free!
arespace
Jun 22 2020, 05:36 PM
I'm in for one. Thx.
pilothyer
Jun 23 2020, 08:30 AM
QUOTE(Mikey914 @ Jun 19 2020, 03:19 PM)
Free Shipping and new washers included...…….I'M IN
frostyf
Jun 23 2020, 09:41 AM
QUOTE(Mikey914 @ Jun 19 2020, 09:19 PM)
Mark, I'm in Please!
cary
Jun 25 2020, 09:55 PM
I need one for Matt Carey's car
sungilhan
Jun 26 2020, 06:40 PM
Me also please.
jcd914
Jun 27 2020, 01:13 AM
I'm in for one.
Jim
Mikey914
Jun 27 2020, 11:05 AM
PMs sent to all so far
BillJ
Jul 4 2020, 10:47 AM
mine just puked all over the floor. Should I get this one or the easy one?
Mikey914
Jul 4 2020, 11:27 AM
Really a matter of access. The job with these is getting the rubber stopper in to seat fully from underneath the car. Laying on your back, it can be a chore.
These are also on sale.
BillJ
Jul 4 2020, 11:29 AM
Have a pro two post lift so access isn't an issue. I need this sent stat to get it all done do I have to wait for the GB?
Highland
Jul 4 2020, 02:06 PM
Does anyone ever just pull out the MC with the plastic lines, then reinstall with the plastic lined pre installed or is this impossible to do?
914Sixer
Jul 4 2020, 02:22 PM
What, you want to do it the easy way? Best to disconnect the rod from the pedal assembly before dropping the master cylinder down.
Montreal914
Jul 4 2020, 02:24 PM
It would be nice to have some explanation as to the benefit of these parts and where is the improvement compared to the stock part.
I have read that installing the plastic lines in a new MC can be a pain, how does this part solves the problem?
How to use them, sequence of assembly, etc...
Thank you for what is probably a good product
Mikey914
Jul 5 2020, 07:10 PM
If you have ever tried to install the stock while on your back in a driveway. The "easy" version allows you to not have to try to pull the rubber stoppers in place while you have very little room to move around.
The Easy version has threaded nipples that allow for attachment mechanically without a lot of pressure required.
Highland
Jul 6 2020, 12:06 PM
@Mikey914 do you sell the pre-bent plastic tubes and short connecting tubes to the reservoir? Did not see it on your site.
Mikey914
Jul 7 2020, 12:33 AM
I do not have pre-bent lines but can provide the plastic lines required as well as the Hydraulic hose used to connect to reservoir.
I'll work at getting this listed up this week.
-Mark
