Symptoms:
Starter will turn a few degrees but will not turn over the engine when I release the key the starter will turn over a few more degrees as though I still have the key in the start position.
What I checked:
- Battery was tested and showing 12.58 volts
- Checked current draw looking for a dead short on negative side of battery (no current draw indicated)
- Also had a charger (in start mode) hooked up while starting
- The starter was rebuilt and a new solenoid was installed the starter was bench tested
- The starter relay was also removed and bench tested
- Visual inspection of the wiring in the engine bay and underneath the car, I could not see anything obvious
Recent work done (may not be relevant):
- Installed 123 D-Jet distributor (using curve D)
- Rebuild Fuel Injectors (Mr. Injector)
- Adjusted Fuel Pressure was 26 psi is now set at 28 psi
- New cap, rotor and wires
- New spark plugs W7C W175T2
- All new vacuum lines
- Compression checked #1:145 psi, #2:135 psi, #3:145 psi and #4:145 psi
- Replaced activated charcoal in charcoal canister (no more gas smell)
