QUOTE(Highland @ Jun 24 2020, 10:20 PM)
So when I turn right, the flasher works properly, when I turn left, the first few blinks are good then both sides start flashing. The emergency light work properly.
The flasher relay does not fully seat in the socket. Do I have the right relay? Any reference where to buy a new one and correct part number.
The left and right blinkers use the flasher relay in the same way. If you see a difference of the tachometer indicators between left and right blinking, then likely there is a minute difference in wiring to the exterior bulbs or the wattages of the external lamps are different.
The both indicators flashing is a common characteristic of the secondary relay in the flasher losing its efficiency. You can get another OEM flasher relay or go with a modified EP26 as mentioned earlier. I resell EP26 already modified. With the EP26 you can then change to LED turnsignals without issue.
